I’m about to fit a 62kw in the wife’s leafLeafs came out in the UK 2011 - might just have reached its natural end of life, if this is the pack I think it is in Aberdeen then it looks like its a 24kWh pack so a relatively early model. I'd also be looking to swap it for a larger pack at this stage.
Another option,
Get a cost to run the broken Leaf upto the breakers on a transporter.
They fit the battery there, drive the Leaf home.
That's presuming the battery is actually the problem. I can see issues if the 'new' one is fitted and it still won't work..
we can ship if the sender fills in a DGN. Dangerous Goods Notification.On an EV forum I have been following a discussion about the repair of a faulty Nissan Leaf EV. The owner is now considering replacing the entire battery, which is in a sealed box under the car and weighs 300kg. He has located one at a breaker's, 450 miles away, but it is "collect only", and the Seller does not know of any shippers or couriers who will handle an EV battery. Any suggestions?
exactly my opinion . The future of EV's are an unknown. Virtually all my cars ( last one excepted) have been over 10 years old. But I can see how my son is always getting into calculations with the one he uses. Simple things like dropping of at airport needs careful.planning.I'd give the entire notion of an unknown used EV battery a body swerve, to be honest. Which does have significant ramifications for the future of EVs... Does this mean that electric cars older than, say, ten years are going to be unsellable, if you need to splurge £12k for a manufacturer-supplied replacement battery pack?
Yikes - this post went off-topic, quickly!
I’ve not been in a breakers for years – and I’ve not seen too many “pretty handy with the spanners”, but I have seen an awful lot up and down the country who are artistes with the gas axe and FBHs!I was going to say that but went with the V8 quip.
Breakers are often pretty handy with the spanners. Presume they've already "dropped" the battery out of the donor vehicle?
But end of life would include the battery, too.Leafs came out in the UK 2011 - might just have reached its natural end of life, if this is the pack I think it is in Aberdeen then it looks like its a 24kWh pack so a relatively early model. I'd also be looking to swap it for a larger pack at this stage.
If they don't have an ADR Certificate, and hire an ADR compliant van with all the appropriate safety equipment, and use an appropriate overpack, then it's a fairly big legal no-no.I know nothing of shiping EV batteries but why couldn't the buyer hire a Van and collect it or are there other transport practicalities to consider?
Most EV batteries are mounted in metal or steel-reinforced plastic boxes.How is it mounted in the car ?
On rubber ?
Where does the fire exit upon ignition ?
E.G. this 14kWh Range Rover Hybrid battery is in a cast aluminium tub that has channels for glycol temperature control, and with a sealed-on pressed steel lid:
It is bolted directly under the floor, in the same way as a petrol tank. The battery management circuits ( BMS ) which protect against overtemperature, over- and under-voltage, and balance the cells are inside, and contactors ensure that the output is not "live" except when driving. Most packs also have a pyro-fuse triggered by the airbag circuits.
the cost of owning an ev is expensive for a pile of scrap 10 years later ( the shell of the car )I think people should stop buying EV's personally, just buy and keep fossil fueled vehicles on the road for the time being, until synthetic or hydrogen fuels are developed and available nationally .
The government can't force people to buy EV's, they can try to ban the sales of diesel/petrol vehicles, but the public transport system would just collapse under the load.
Lets' face it, most people never buy a new diesel/petrol car because of the cost, how do the idiots in government expect most of the workforce to buy EV to travel to work every few years?
And then there's the cost of relaying all the national grid power lines buried under the ground/streets when the power draw (EV's charging at night) exceeds the underground cable carrying capacity, causing cable fires/shorts....
Most underground cables are probably getting towards a 100+ years old now.......
Then there's the "Tip Hazards" of all the charging cables laying over the pavements....
We had a company shipping an ejector seat from Turkey recently. I asked if the firing cartridges and rocket tubes had been removed. They didn't know what I was talking about. I asked for a few piccies - and no they were still on the seatso this pyro fuse will not be in play when transporting on a pallet.
I wonder if the one in the CCF hut at school back in the 80's was similarly equipped . . ?We had a company shipping an ejector seat from Turkey recently. I asked if the firing cartridges and rocket tubes had been removed. They didn't know what I was talking about. I asked for a few piccies - and no they were still on the seat![]()
There is a garage that specialises in repairing leaf batteries down London way they have plenty of bids on YouTube, there are known fail points because of the way the battery overheats, much cheaper than replacingOn an EV forum I have been following a discussion about the repair of a faulty Nissan Leaf EV. The owner is now considering replacing the entire battery, which is in a sealed box under the car and weighs 300kg. He has located one at a breaker's, 450 miles away, but it is "collect only", and the Seller does not know of any shippers or couriers who will handle an EV battery. Any suggestions?
That could have been exciting for some trucker.We had a company shipping an ejector seat from Turkey recently. I asked if the firing cartridges and rocket tubes had been removed. They didn't know what I was talking about. I asked for a few piccies - and no they were still on the seat![]()
