I've spent way too much time making a sink for the welding of one of the legs of the float valve on a Hitachi carb. I cut it out of a piece of 8mm copper, filed to fit around the spot face of the socket that the brass valve screw up against, got it perfect.
Then I drilled through so it could be used to mount the new "leg" to. Or rather I started to drill it - 2.5 mm, pillar drill on max speed, take it easy, but, maybe not easy enough... It looked like the high speed and not enough clearing caused the swarf to melt and bind - snapped the drill bit... I tried and tried to "unscrew" it with some pointy electronics pliers, no way was it shifting. So the decision was made to turn the piece around and drill the other side. Well bu**er me, I did it again!
So now I'm on attempt no 3, pics when finished, with a lot of luck will have 2 legs on the carbs float pivot...
Edit to ask - what's the trick with this copper drilling - less speed?
