Mrs Browser sent me a link to an advert for what looks like foil-faced bubble wrap which you cut to size and slide behind your radiator, which somehow saves you money. Reading up online the idea is supposed to be that it stops heat from the rad being lost to the wall it is mounted on, reflecting it back into the room. Obviously, radiators emit heat by, well, radiating, but the heat is them spread around the room by convection, so this should, in theory, negate some of the loss through the wall.
I'd notmally put this in the mental file marked snake oil, together with tealights under plant pots to heat your whole room, miracle cleaning products and honest politicians but thought I'd ask in case I'm missing a trick.
