MysterG
- Wiltshire, UK
Nah. They need to be plain and smooth.
Think of the dog tag discs but smaller.
I sort of meant smooth as in no holes or protrusions like the suggested rivets, but I take your point.If you are using punchings they will need to spend a fair bit of time in a tumbler to get them smooth, half inch diameter isn’t something that you can fettle by hand.
Bob
Of course ... if you can find me some in steel or copper around 1/2"Is it not easier and cheaper to just buy them
Aluminium Tree Tags
Sequentially numbered Aluminium Tree Tags in pack sizes of 50, 100, 200, 500 & 1000, available with or without nails.www.treemarker.co.uk
I'd love one if I had the space.I know I keep banging on about it but a flypress with a half inch(non centred) punch is the perfect solution. Better than hitting things with hammers though you could use a flypress/arbor press to operate such a tool.
Why would you do that? Because a flypress is a fantastically versatile tool for all sorts of metalworking.
You know us - always willing to help out when needed.I'm teetotal![]()
Well it's sort of the last place I would have thought to look, but I should have realised that Amazon sell everything these days.Search Amazon there are hundreds of options from 8mm up to 25mm
Agreed- and dare I say a big old fly press could probably live outside under a cover if space is an issue- suitably covered in oil or something and a tarpaulinThey look plasma cut to me. That ragged edge will drive you nuts if you try to smooth it.
Flypress will punch a perfect round in less than a second. Couple of dozen might take a couple of minutes with most of the time spent placing the material under the punch.
…ok I was trying to ease him in gently…Under cover, you say?![]()
A bash with a hammer is fine.I bought a couple of Stakesy's hole punch sets. Quite happy, but the round 'off-cut' is a bit wavy. Would a quick bash with a hammer flatten it enough, or has the disc to be faultless?
Holy moly! Just looked at their website... Very different to when I bought my bits. And the prices!
