AndyStobbs
- North West England
Got a job on at the moment, mini cooper s in need of a clutch. Its R53 model number. Its also been reported to have an engine rattle which I've witnessed for myself.
Usually queit from cold start with 3.75bar oil pressure (according to factory fitted gauge), but typically rattles from a hot start. Amazingly, turning it off and restarting seems to cure the rattle (usually after one cycle, less often it could take 3 cycles).
Rattle sounds to me like timing chain area. It has already had the timing chain tensioner replaced (which is hydraulic) and seems to have made little or no difference, though this seems to be a succesful fix in most cases.
I think its oil pressure related, but cannot get my head around how a shut down and restart is making it quieter. The oil pressure doesn't vary from the original hot start to any subsequent off/on cycles.
I'm also wondering if the chain is stopping in a more favourable position on subsequent starts and tensioner is able to take up slightly more slack.
The engine is out at the moment and I want to try and make the right diagnosis first time around.
So if anybody has a cooper s, and has experienced similar that input would be fantastic. Failing that, could any owners of a cooper s report your oil pressure tendancies please.
Thanks
Also, I plan to lift rocker cover and check lifters etc. tomorrow, also timing cover is coming off anyway for investigative purposes. I don't want to put a chain kit on it for no improvement though.
Andy
Thanks
Andy
