Arc Tourist
- Wales
Old time tyre support for manual removal ?
Or some kind of foot operated juicer ?
Odd-shape is a ducks head.I had to use one of those tytre machines to change landrover tyres when I was 16/17. As above had a long lever with aball on one end and an odd-shaped forging the other for taking tyres off and re-fitting them. It was hard work.
That one also had an air ram on the side with a foot on it for popping the beads.
I have used a coats center post many times, and the beak breaker is powerfull, but not for aluminum rims.I have a similar type bead breaker, its got a bit more scope and a lot grunt than the one on my tyre machine.
It works much like pictured above.
I bought an old May Tire-A-Matic, and the bead breaker is a steel wheel that comes down with an air cylinder
and the rim spins by motor.
Just did some aluminum rims, stuck pretty bad, no problem, just light touch on the air valve control, and let the rim
go round & round, while the steel wheel slowly does it's job.
Yes.Sounds a bit like the truck tyre machine Fred. this beast rotates the wheel and another wheel shoves the tyre straight off the rim.
Absolutely not! (I'm not sure that is)You sure it is not chalk? specifically French chalk.
We have one of those @8ob for the Merlo and loader tyres good bit of kit, the agg men next to home have the bigger version for tractor rears.Sounds a bit like the truck tyre machine Fred. this beast rotates the wheel and another wheel shoves the tyre straight off the rim.
