I have a 1981 Draper drill press and there is a hole in the side of is that I tried filling using 7018 rods. I think it's cast iron around 3-5mm thick and it doesn't like the heat so it's cracking around the areas welded. Initially I placed a piece of 1.5mm thick mild steel behind the hole, welded to that and then built up layers. I managed to cover the whole thing. Then I started grinding to get it level and there were areas that weren't full, so I grinded them out and started filling again. After spending many hours trying this approach, I think it might be time to try something else.
I want it to be a structural repair and then want to be able to mount something on the outside.
What approach would you take?
