Nice bit of turning what will you use when the glue deteriorates ?Today I made a simple aluminium ring with a 36.9 mm through hole:
I've got a (rather expensive, but generally very good) oil can, but the oil seal doesn't seem very well thought out. Having made the ring, I mounted the body of the oil can in the lathe and got it running true with a bearing tool in the tool post (photo taken after swapping the bearing tool for a cutting tool, obviously):
I then skimmed the first 10 mm of the outside down to 36.9 mm (it was 37 mm at the rim, tapering up at about 3° included angle):
A bit of superglue joined the two bits together:
Once the superglue had been left for 5 minutes or so to do its thing, I took some gentle cuts to machine the face to length, machine the outside and also to cut a small rebate on the face to match the diameter of the stock seal:
A quick test-fit before removing it from the lathe seemed a good idea:
The oil seal still bears on the rim of the can itself, but the aluminium disk supports the outside better and hopefully that'll result in fewer damaged seals.
Dunno. Replace it with Loctite 603 probably (that's what I normally do with metal-to-metal gluing). It shouldn't matter too much if the glue does fail: as the aluminium sits on a reduced diameter bit with a (small) shoulder, it shouldn't go anywhere even if the glue fails. The oil seal is still formed by the o-ring thing pressing against the rim of the bottle. If the aluminium bit becomes loose, it'll still serve the purpose of stopping the o-ring from rolling over the edge.Nice bit of turning what will you use when the glue deteriorates ?
I've got a few of those around the workshop, very handy for oil, soluble cutting fluid etc. If they can withstand the chemicals that they contain, a bit of oil should be no problemNice bit of turning what will you use when the glue deteriorates ?
I use the empty washed out squeezy 150 ml hair dye bottles our Ukrainian gal uses when hiding the grey mare on her head . If I drop one it does not damage them .
Discovered this morning that the local ladies hair dresser has a few most weeks
I know that pain. On paper, slot profiling steel with a small end mill works great... in practice not so great
That was a common problem on some Fords that had tempered seats , also VW air cooled engines if Champion spark plugs had been fittedView attachment 444561
I've decided to work on my little punto for 10 minutes...
Well it was supposed to last 10 minutes.
So the only job which shouldn't take more than 10 minutes, it turn out to be a nightmare.
Spark plug broken in its seat.
I've had to accurately remove any single ceramic fragment prior to replace it preventing a disaster.
Imagine the amount of damage a little piece of ceramic can do if going inside the cylinders
Ha ha did that a couple of days ago, brand new 8mm extra long aluminium cutter, forgot to disable the lead out transition so it did a nice wee arc into the vice and snapped like a carrot
Stefan Gotteswinter did a YouTube video on cutting sheet recently he suggested doing many light cuts with fast feed rates.I know that pain. On paper, slot profiling steel with a small end mill works great... in practice not so greatIf you're patient enough maybe... but I always try to push the DOC and feed too hard
