Mick Annick
- Burgundy, France (450 miles SE of Somerset)
Well it seems like our whole industry could be in trouble!
These rules are nothing new, but DVSA and the Police are enforcing them more than in the past.
I totally agree. I too wouldn't weld anything structural that way. I don't even like 6013. Most stuff I weld is with either 7018 or 7016.6013 fair enough, it's not ideal though. Slag entrapment is too easy on fillet joints. And I wouldn't ever recommend it for a structural purpose.
7018 is not recommended for vertical down at all. Most of the datasheets specifically state this.
Chain, funny as I was thinking something similar. Keep them coming, I can already see i may end up not using those hooks at all, and maybe not even welding anything.All I use on trailers is loops of chain,
interesting , as pictured which face goes to outside of truck/trailer ? top or bottom ? I would fit with bottom as then all four fixings are in shear when load applied , yet if fitted with top(at outside edge) as in pic it would be only the top two fixings taking the initial load.,the bottom two only being a pivot point when the top two had sheared....be interesting if some had the capability of the break away point either way around.have allays used recessed trailer lashing rings, made a template up for a router that cuts the hole. and use it to line up on the chassis rails, they are rated to 500kg each and have 8 on my trailer, happily towed 3 tone dumper all the way back from Wales using them.
should only take an afternoon to fit 8 and they cost around £5-6 each, and when not using them they store nicely out the way when carrying flat loads
So is it still legal to use rope hooks with rope to secure a load if using the old fashioned roping methods?
Thank you @AgroshieldRead the document linked to above. The info. you require is bottom of page 23/top of page 24.
Straps are quicker, if you only use 1Thank you @Agroshield
Looks like the days of roping and sheeting a load have properly gone.
I've still being using ropes for hay and straw![]()
They're intended to fit flat on the trailer floor.interesting , as pictured which face goes to outside of truck/trailer ? top or bottom ?
Same could be said for bale carrying round here. I passed one the other day 10 x 4ft bales on a flat bed, two layers 6 on the bottom, two a abreast, 4 on top, back of a pickup with one on the bed. 12 ft ifor trailer. Two straps.The guide covers straw bales. I think it says 1 strap per row and two on the front and rear rows (p.38). General agricultural haulage is page 29.
For me, it was interesting to see what it says about scaffold wagons. No-one around here does what it says.
ah you mis read, I understand how they are inlet into floor ,its which way around they are fitted I am asking as the "correct" way to me is wrongThey're intended to fit flat on the trailer floor.
Gotcha. As pictured, I'd fit so the load is pulling down, away from the end with the pivot. That's because the ring is completely free to take up the line in that direction. Other way round it's not clear how far past vertical it can pivot. The load could be trying to dislocate the joint instead of trsnsferring to the pivot. With 8mm bolts the fixings arent likely to be a limiting factor.ah you mis read, I understand how they are inlet into floor ,its which way around they are fitted I am asking as the "correct" way to me is wrong
Go
Incidentally one suppliers says that this sort of fixed can't be rated at over 500kg. He doesn't give a source.
Thanks for the link, very informativeSee: https://www.gov.uk/guidance/securing-loads-on-hgvs-and-goods-vehicles
Also seems to be here as pdf if that is useful:
