need help translating the description on ebay
its function is described as
im trying to biuld an automatic feeder for the geese, all i need is some sort of timer that will run off a 12v car battery and switch a relay on for approx 20 seconds every 8 hours
i cant make head nor tail of the description above, will this do it ? or can anyone point me at something that will
thanks Andy
DC12V Trigger Cycle Time Timer Delay Controller LED Display Digital Switch Relay | eBay UK
A: Invalid trigger again B: Re-trigger re-clocking C: Trigger relay reset again to stop timing. P-3: Cycling: Turn on T1, disconnect T2, infinite loop. P-1: The signal triggers the relay to pull in.
www.ebay.co.uk
thanks Andy
. I will try searching for 12v time clock and see if that throws anything up
