Right, who can help me..
Picked up a 100L Clarke Boxer 2 compressor, 3hp single phase 13amp, guess its 3/4 years old and looks like it has only had very light use. It starts fine, fills to about 5 bar and then stutters before throwing the 15 amp cut out. If I drop the pressure in the receiver it’ll start again just fine but the same thing will happen and it only ever reaches the same 5 ish bar.
- Non return valve replaced and working fine
- Pressure switch is fine
- I was away for a week so dropped the motor off at a local rewind place to give it the once over, they replaced both capacitors and bearings (although they didn’t run any of this past me just landed me with a bill..) Both new capacitors are in range on my multimeter
- Runs quite happily with no load
- Pump seems fine, it gets to 5 bar in less than two minutes which seems about right. Turns easily by hand including just after tripping the breaker. Oil has been changed with bog standard compressor oil
- I’ve checked all electrical connections and now wired the motor straight into mains and bypassed the thermal cut out just to be sure. No change..
- 238V at the plug
