That is the 2 5/16" ball and IIRC they are rated to 30k lbs.
Our rules are a lot stricter though. A similar weight setup here would require air brakes a much more substantial hitch. Six weekly testing and a whole host 9f other stuff
Or too loose.I bet they had been over tightened - can't see them breaking otherwise unless badly rusted.
I know. Farmers switched to Rangers when LR stopped doing proper hitches. I got a Ranger because it had a man sized towing hitch. I reckon their sales will drop and they will have no clue as to why!The new Ford Ranger in the UK comes fitted with a 2" square receiver, just like the American ones.
Maybe they are allowed now.
I had a genuine LR NAS 2" reciever hitch on my D2, nothing weedy about, was definitely stout and had substantial bracing to the chassis railsIndeed - I cut he bottom bit off on mine as not needed. Plenty of bracing though unlike the plug in style ones.
I don't like the square tube plug in style. They tend to stick out too far to get clearance. Might be ok onroad but offroad sideways forces can be pretty high.
Dixon Bate adjustable as fitted to older Landrovers are the best I reckon.
The chain hooks are welded to the hitch cross bar or bumper.Four (+) more potential points of failure than a fixed hitch?
Decent chains, though. What are they attached to?
Well....I have worked on a few trailers with electric brakes.@mtt.tr and I were talking about the brake systems on US trailers and how there so much better than ours. Over run brakes are so out dated. I really like the electronic brake systems and how simple they are.
Yay !!!!I have a 2" socket on the back of my 16 Challenger. Got a Reese ball mount in it, shimmed to take the play out - it had lost close to an inch of the 5" lift it gave me due to slop. I redrilled the pin hole to get the ball closer to the back of the car. I found a suitably highly rated bolt in 50mm ball in Germany to replace the 2" US one. Works pretty well.
I did modifiy the way the hitch attached to the rear of the car so it used the full strength of the rear "chassis" leg box section, rather than the thin lower single skin on the same section.
I always found the US wiring socket hilarious - a connector simply dangling on the end of the wires.
Considering how often trailer electrics go wrong I would be rather concerned. We get loads of salt on our roads. Couple that with being dunked in the sea and dragged through mud and over run looks more promising.@mtt.tr and I were talking about the brake systems on US trailers and how there so much better than ours. Over run brakes are so out dated. I really like the electronic brake systems and how simple they are.
Yes but that still had a proper chassis!I had a genuine LR NAS 2" reciever hitch on my D2, nothing weedy about, was definitely stout and had substantial bracing to the chassis rails
Yup, and here I was doing a simple layout to see if I could incorporate hydraulic brakes (surge brakes) inside the same backing plate with the electric brakes, for a backup.....Considering how often trailer electrics go wrong I would be rather concerned. We get loads of salt on our roads. Couple that with being dunked in the sea and dragged through mud and over run looks more promising.
I hate them all the same though!
Remember one thing....there is a single piece of 12ga wire to operate those brakes.
They do not failsafe.
Both points are true but there’s many ways this could be improved on. How many people run round here with no working over run brakes. The trailer plugs on US vehicles are awful but the brake design itself is nice design and I like that you can adjust the power in the vehicle.Considering how often trailer electrics go wrong I would be rather concerned. We get loads of salt on our roads. Couple that with being dunked in the sea and dragged through mud and over run looks more promising.
My neighbor has a 3/4 ton dodge pickup with a Cummins diesel.Both points are true but there’s many ways this could be improved on. How many people run round here with no working over run brakes. The trailer plugs on US vehicles are awful but the brake design itself is nice design and I like that you can adjust the power in the vehicle.
