If you had 5 printers would you sell them all to get a bamboo?Lots of things not included with the P1. Man of your means: get the full house Carbon X1. I guarantee you will thank me for it.
That links to another thread on here??I use 0.6mm nozzles almost exclusively now, speeds things up no end. All thanks to this video by Thomas Sanladerer;
Why 0.4mm nozzles are obsolete.
Have you got a link . I Have some time (in the wrong place) next week so some research would not go amiss.I had a little look and it seems that a four colour printer can be purchased for £860, which isn't bad considering the money I spent on my Ender 3 V2 to bring its performance up. If I could find a buyer for mine, I would be strongly considering that P1.
One thing I was confused about though, the enclosure panels are not included?
TPU is slow to print that’s just how it is. If you’re making lots of the same item you could make 3D printed moulds and use a flexible casting resin.
bambulabHave you got a link . I Have some time (in the wrong place) next week so some research would not go amiss.
My bad, I musta ******** up the link. Try again;That links to another thread on here??
I've just had a quick fiddle in cura (without actually printing anything and swapping from a 0.4 ot a 0.6 or 0.8 nozzle does indeed speed things up dramatically.
I'll get some orders up and see what the printer can cope with
Not necessarily, it depends what you want to do. If you're printing small intricate things maybe so but for more 'engineering' practical things you're probably not going to notice much and does it matter? Prints can also be stronger as you've less layers to tear apart.But then the quality goes down doesn't it?
Ultimately it comes down to the efficiency of your hot end and capacity of your power supply. At some point the heating element simply won't be able to keep up with the flow rate.I've just had a quick fiddle in cura (without actually printing anything and swapping from a 0.4 ot a 0.6 or 0.8 nozzle does indeed speed things up dramatically.
0.6mm is a good spot for the Ender3 for example but go up to 0.8 or 1mm and you have to turn the travel speed down so the hotend can keep up...
Think of it like milling - a 10mm tool is no less accurate than a 5mm one so long as theres no internal features smaller than the radius but the time saved can be significant.But then the quality goes down doesn't it?
Which is why you switch to a CHT nozzle or similar so you can crank heat into the filament faster - the limit for most printers is getting the heat from the nozzle into the plastic, not the heating element.
A volcano is cheaper but not a straight swap and the longer extrusion heat zone can cause issues with keeping TPU at elevated temperatures for a while - same as injection molding the longer you keep TPU up at full melt temps the worse its properties get.
These were both done with 1mm wide extrusions, more than high enough quality for their intended use:
(edit - as some were talking about it, larger extrusions are generally stronger as you have less stress risers and the interbond temperature is kept higher from the higher thermal mass)
I guess it also depends if people have any work to be getting on with.Yep, there is that too, efficiency covers a multitude of sins. Once you go down that rabbit hole it is an endless voyage of discovery.
For tinkerers I say knock yourself out, have fun playing with 3d printers in some horiffic never ending voyage.
For the dedicated professional or commercial application it is an onerous task offset only by the fun to be had playing with someone else’s money so that you can get more of it back.
In the middle ground are people like me who just want to make things with a printer that just sits there and works. I came really close to building a Voron just to get the minimum level of performance that you need for prototyping. Then the X1 came out and there’s not that much of a trade off with either price or performance.
i guess it just depends on how much time people are prepared to spend making something work as opposed to getting on with work.
