Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
It's the bit which supports the bottom of the rudder, from the keel.I dont know what a skeg is, but its going to sink
 Cheated a bit as this was a pre welded (at the corners) bit of old server racking. All I've done so far is weld some feet on and fit an exhaust clamp at the top:
 Cheated a bit as this was a pre welded (at the corners) bit of old server racking. All I've done so far is weld some feet on and fit an exhaust clamp at the top: ).
 ).Even my stick welding seemed to go alright (if you don't look at it).
I could easily be wrong but if the black tube underneath is the exhaust and the space is enclosed where does the fresh air come from prior to being heated?
Nice welding, mig ? Steel or alu ?
Stick and steel with crap SIF electrodesNice welding, mig ? Steel or alu ?
Nice welds, better than mine today, think my helmet is dying.Stick and steel with crap SIF electrodes
Difficult when you can't see what you're welding.
Yeah, but......What's the saying about a workman who blames his tools?
 ) and happy days ,
 ) and happy days ,
 any way whilst in there this time I got some details of the switch and with some google fu found a supplier of said unobtainable switch from hikoki ( you can only buy all the tronics inside as bundle already pre soldered together at wellover a ton plus Vat ! ) two switches + vat and delivery less than £20
any way whilst in there this time I got some details of the switch and with some google fu found a supplier of said unobtainable switch from hikoki ( you can only buy all the tronics inside as bundle already pre soldered together at wellover a ton plus Vat ! ) two switches + vat and delivery less than £20  so came in happy with myself just to be told the murican fridge freezer had given in , this maybe a far more costly replacement mind it's given 17 yrs of sterling service so not so bad I suppose .
  so came in happy with myself just to be told the murican fridge freezer had given in , this maybe a far more costly replacement mind it's given 17 yrs of sterling service so not so bad I suppose .Silver pipe is the exhaust going outside. Combustion is narrow black pipe with filter on the end.I could easily be wrong but if the black tube underneath is the exhaust and the space is enclosed where does the fresh air come from prior to being heated?
Ha good man, great effort, a man after my own heart....I often spend hours trying to fix something, which would be easier to bin and buy new, but where's the fun in thatWell yesterday I made the multi tool work for the second time .......the previous job on the badly misaligned / worn contacts in the switch didn't last so long so a bit more was needed
firstly I broke up an old switched socket for some parts then punched out one of the copper contacts and the old contact of the rocker switch and soldered in the doner
reassembled ( I did have to double up on the reading glasses to see what I doing) and happy days ,
for how longany way whilst in there this time I got some details of the switch and with some google fu found a supplier of said unobtainable switch from hikoki ( you can only buy all the tronics inside as bundle already pre soldered together at wellover a ton plus Vat ! ) two switches + vat and delivery less than £20
 . As AVE would say........you cant #### it anymore !
Good job mate, is it just me with the warped mind?I finally got around the fixing my front gate stop, before it rusted through completely.
A piece of angled steel that ive been saving for several years came in handy.
A couple of secondhand brass screws came in very useful, too.
The bricks were already cracked, by the way.
