Noods
- Ipswich
Hi..
Has anyone experienced this issue when drilling mild steel..
Drilling 2 x 8mm holes through 6mm thick mild steel..
Pilot holes drilled and first 8mm hole drilled through without any issue..
Hole 2 again pilot hole drilled first with coolant and get half way through with the 8 mm and the drill won’t go any further, so i sharpen the drill bit and try again but no, it does not want to know ( always sharpen my bits without issue normally) so, i get a brand new 8 mm drill bit HSS of high quality but no, it won’t touch it either..
All i can think of is perhaps the heat has case hardened the steel.. ? Or perhaps could there be impenetrable elements within the steel.. ?
Your thoughts… with thanks..
or plasma cutter....last resort...lol.
