Early this afternoon I melted a bit of aluminium alloy - just pouring to ingot - less than a kilogram.
For some (very fortunate) reason I decided this evening to weigh it - and unlocking the workshop was greeted by a pungent smell. Got stronger as I went through the fire doors into the foundry - somethings burning.
Now admittedly there was a bit of a splash as I poured the ingot, but nothing exceptional - but here were are with the floor channel Acco drain totally burnt out, the timber of a stout castered dolly that was in the foundry still gently crackling with red hot embers, and charring round the fire extinguisher and up towards the only bit of timber wall cladding.
This could have been bad - and I mean REALLY bad - if that bit of timber clad wall had gone up in flames the whole back wall of my workshop could have burnt :bugeye:
Oddly there was a floor mop and bucket totally melted and burnt out that I'd used to mop up antifreeze spills from recently replacing all the furnace coolant - had it dried and spontaneously combusted ? I don't think so but have no proof - I THINK what happened was a splash of molten aluminium had got into the (dry) floor drain channel which probably had quite a bit of fluff in it, and as it burnt along it's length took the rest with it.
But heck - this is a rude awakening.
I've moved the still glowing bits of the dolly outside and doused it with a few buckets of water, and sprayed every where that there has been charring with a hand pump water spray, and will come back in an hour and re-check everything.
...as stated above after i have finished welding i never ever just shut shop and go in doors, stick around for at least 30mins cleaning up etc and sniff all that time for smells.
