If you guys think that would do then great… Only thing i would need to find then would be a geared pulley and a bearing plus housing yes?What is it to be used on? Many of these import spindles are only intended for CNC wood router type things, so they have high speed but not really up to doing ferrous milling, atleast not at slower speed with bigger cutters.
When I was thinking about adding a spindle on lathe I went with a VDI40 live tooling ER32 spindle. Its intended for CNC lathes to add milling. I havent got around to adapting it yet
Quality will be very good provided its not worn out.. something like:
VDI 40 Driven / Live Tool with ER32 Collet. (Axial) DIN 1809 (Right Hand) CNC 2 | eBay
Find many great new & used options and get the best deals for VDI 40 Driven / Live Tool with ER32 Collet. (Axial) DIN 1809 (Right Hand) CNC 2 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Yes mte from scratch and very limited space wise..Ah, I wouldnt recommend either, if your building from scratch. Do you have a lathe or acess to a lathe?
How much space is your limited space?
Is it a stand alone mill, or a milling head to usewith your lathe cross slide. If stand alone, how much space doyou have.Yes mte from scratch and very limited space wise..
Sorry yes it’s been a while… Stand alone as i don’t have a lathe yet..Is it a stand alone mill, or a milling head to usewith your lathe cross slide. If stand alone, how much space doyou have.
Good to see you back BTW
If you buy an old lathe, you will also be-able to mill on it.Sorry yes it’s been a while… Stand alone as i don’t have a lathe yet..
Having folk machine stuff for you is expensive. Will defeat the benefit of saving money building your own. If building your own is the objective, again buy old late and use the cross slide and bed to-get your movement, and build your head central to the lathe bed.I can get parts machined if need be by local engineers with lathes etc yes, i will construct the remainder myself, tig welding etc with columns filled with expoxy G .. That won’t be an issue i’m sure it’s the head that i need to ensure i can source it’s as parts, to modify or complete..
That's what everyone told me. I didn't listen and bought a mill first. Barely ever use it, whereas the lathe gets used all the time.I'd have a lathe before a mill.
I actually use the mill all the time now, whereas the lathe rarely gets usedThat's what everyone told me. I didn't listen and bought a mill first. Barely ever use it, whereas the lathe gets used all the time.![]()
