Interesting...obviously you know about guitar builds? Got a couple of questions regarding bridge bowing/bulging. This isn't the section for it needs to be over inWell it works for guitars. It’s called a truss rod, but it really needs to be put into a groove that is curved along its length, so that when the two pieces are glued together it forms a bow shape. When the nut is tightened at the end it will pull the shelf into a shallow curve, counteracting any sag due to the load (assuming you’ve installed the shelf the right way up!).
Price gouging is the cause of much of the rises. Profiteering is another..Everything is expensive nowadays.
Or a T piece steel (aluminium) rebated into the shelf.I would wonder about a metal strip screwed to the back edge of the shelf
Great minds think alike...I had not seen your reply...honest.I dont think tensioned rods will work. MDF will creep over time. It does not have the compressive strength that proper wood or other materials have.
Better would be to use thicker mdf shelves, route out the edges and insert 10mm or so steel box section and a strip of mdf or veneer to hide it on all sides.
When I say "as the shelf bends" I don't mean the shelf will deform (it will, but that's not the point) I mean, imagine what will happen to the rod, as the shelf is loaded and it begins to bend. If the rod is bang on the centre of the board, it will just bend. If it's towards the top of the board, it'll be compressed, if it's towards the bottom, it'll be in tension. For maximum impact, it'd need to be as far to the bottom as possible (or below the bottom!)My thinking/hope is that it would eliminate any sagging in the first place (to a point) as opposed to being a way to counteract it over time.
Or at least constrain it to the point where it doest draw the eye.
Google search sagulator to calculate saggage on shelves.
Truly a tragic sight
Then you get the fall out and manufacturers having to pay extra for raw materials passing it on to the customers who in turn need more wages to be able to afford the increased prices....or the manufacturers will go out of business...meaning workers loose their jobs. This has a knock on effect as other businesses can't sell to those workers who are now out of work.
The MONEY must be going somewhere. Mainly to those who do not need it sadly.
The end result is the OP struggles because his customers simply cant afford what they WANT and the OP WANTS to produce.![]()
Radical suggestion - veneered steel box section frame
I use it. However the answer with MDF + books is always going to be unfavorable.
Nail. Head.
Already using 26mm @ £120 a sheet.
Thing is with MDF as it gets thicker it gets insanely heavy, and start sagging under its own weight.
Tension rods work for large format doors, but yes perhaps not in this application, glue is drying so I'll find out soon.
Box section thing doesn't seem to make a difference, it's as bendy as the MDF though it would probably constrain the sag from getting worse over time.
