Try one of these tools - really helps and you get a lovely finish. Also use them on steel.Anyone run their standard motor at a higher hz through their hfd to achieve more speed not looking to go mega fast even 250rpm would help my harrison 140 is limited to 750rpm, its more of a limitation on smaller aluminium parts
That was kinda the plan try it at 70hz leave the base at 50hz and only ramp up if I'm on small aluminium partsAssuming that as you want higher speeds the diameter of the parts you will be turning will smaller I don’t see any reason why you couldn’t try and use a higher speed. I don’t think I’d go mad and set something like 100hz but maybe 70-75 hz would be achievable (take it up in steps, and monitor the bearings and motor temperatures and listen out for anything that sounds a bit strange) - one thing to be aware of as said above is that the torque will drop off as you go above 50hz so I wouldn’t expect the same performance above this. But for light cuts on smaller diameters then it’s probably going to be ok.
Give it a whirl, costs nothing (providing the mechanicals and the motor itself are sound) as long as you are aware of any unusual noises/vibrations etc. You’ll notice if things aren’t right and it starts bogging down.That was kinda the plan try it at 70hz leave the base at 50hz and only ramp up if I'm on small aluminium parts
...its more of a limitation on smaller aluminium parts
Quite so - I’d keep a cautious ear out the first time you do it being a (presumably) older used machine as you don’t know the condition of bearings etc at higher speeds but ultimately as long as they don’t sound/feel rough they are very unlikely to be a limiting factor.Motor/layshaft/spindle bearings are never going to be the limiting factor on a workshop lathe. Ball type bearings that is. I don't know why people keep churning out the same warnings about bearing speeds. They don't fit different bearings to a 2-pole motor than they do a 4-pole motor of the same type because neither will even come close to approaching the bearing's design limit.
