fixedfixer
- Scotland
Novice question sorry. I want to tap a 3/8 th BSF in a brass part. Will an 8mm drill be okay or should I really use 8.3mm bearing in mind I’m only tapping a few threads for a DIY project.
If you try to use too small a pilot you may find problems with starting the thread.
That’s handy cheers.
This may help.
I don’t expect my Aldi Parkside pillar drill is in anyway ‘cock-on’ and 8mm drill could end up 8.3mm you never knowTry it & see. Brass is somewhat forgiving of minor discrepancies, & unless everything on your drilling setup is cock-on, there's no guarantee the final hole won't be a smidge over 8mm anyhow.
Nope. My diy tools and things are a bit limited.
Only for now.Nope. My diy tools and things are a bit limited.
With these factors in mind a starting point is to attempt a thread depth of between 60 and 70 %, actual values depending on the drill sizes available. If these figures come as a surprise then note that Tubal Cain in his book "Model Engineer's Handbook" quotes an even lower figure of 50 to 60% for most materials. If you would like more detail on the subject then Tubal Cain goes into greater depth in his book.
I had to pay for my "metric revision" 30 yrs ago!
This may help.
It'll always drill 8.2 or 8.3 until the day you need an oversize hole, then it will come out a reamer type fit at 8.000"I don’t expect my Aldi Parkside pillar drill is in anyway ‘cock-on’ and 8mm drill could end up 8.3mm you never know
It's a general rule of machining.I liberated mine from a dockyard.I had to pay for my "metric revision" 30 yrs ago!
65 pence look at the price of em now
This may help.
i scored a couple for 3 quid from autojumble and thats cheap
