Kayos
Gone......
- Yorkshire
“Green” boilers … still suffering the same issues …
I mean they have only been in the UK for 30 years, modern unreliable rubbish
I'd rather have a new boiler than an old inefficient one any day
id rather i didnt have to fix it every year, and see the same issues every time it gets a bit cold..... the difference in efficiencies are marginal, the service and replacement costs are notI mean they have only been in the UK for 30 years, modern unreliable rubbish
Ours was frozen again this morning, the other half got up before me then came back whinging about it . She wasn’t too impressed when I told her how to get it working , well I was still in a nice warm bed
Chivalry is alive and well and living in Cambridge.
At my last house the condensate drain pipe ran down to a standard grid drain in garden. The gas Homecare guy pointed out that the pipe really should go down through the drain, rather than just drop onto it, but it would probably never be a problem.Just going to chow down on my dinner tonight and the door bell goes..neighbour from over the road wants to borrow my ladders to check his boiler flue outlet on the side of his gable. His boiler had gone out and would not re-light, I told him the 1st thing to check would be his condensate pipe out the wall as i bet its frozen and the boiler has drowned. Told the wife to put my dinner in the oven and after getting re-dressed in my day time gear nipped over there with my ladders, up the ladders on the gable and sure enough the end of the pipe going into the waste pipe hopper from bathroom was frozen solid. Kettle full of hot water poured onto the pipe and the ice plug dropped out followed by about 2L of water from his boiler, told him to press the boiler reset and see what happens. 30 seconds later she was chooching like a good one and all heat was resumed for himself and his young family...Back home and resumed eating my dinner like a hyena before anyone else knocks for help![]()
Kettle of water did the trick.There's an echo in here.Plumbers eh![]()
My theory exactly. Advise and teach then they will know next time . Hopefully! Be sure to overdo the congratulations when they get it right.Ours was frozen again this morning, the other half got up before me then came back whinging about it . She wasn’t too impressed when I told her how to get it working , well I was still in a nice warm bed
In these days of so called equality what else do you expectChivalry is alive and well and living in Cambridge.
Depends on the installer ?Why aren't these pipe insulated as standard practice?
Well my boilers are still going strong at least 25 years on, parts are readily available and in stock in most places.When the condensate pipe is mounted externally its meant to be a minimum of 11/4 to help stop it freezing, I think the life span of these boilers is better but there was and still is a lot of rubbish about and makes you wonder on the cost savings when a back boiler lasted 30 years plus and some modern boilers have been replaced after 5, something doesn't stack up!
I don't do that as the boot might be on the other foot one day and they do have long memories when it suits them.Or, just leave them to freeze until they listen & twig.![]()
Sexual Equality is good, only when they want it to be.In these days of so called equality what else do you expectYears ago my mother had a flat tyre and asked me to change the wheel for her but I made her do it herself with me watching so if she ever had another one ,out in the fens with no help available , she would know how to do it
I raised both the washing machine & condensing dryer up about 20" by building three plinths of four walling blocks in each pier across the width of the garage at the rear , then put three CLS treated floor joists on top to make the platform for them to stand on.The wife shouted for help earlier tonight .
Utility room (end of my garage) .
Was flooded , water outlet pipe from washer was frozen up outside .
Easy fix it is not there now .
I will have to try and insulate it .
Then Alison claimed pole spot above the washing machine to have a plastic bin roughly 20xX20 ins for all her washing materials.
It's my mancupboard ( she says so ! )Likely not been a cold snap, like this, in the last seventeen years! I don’t think ‘the beast from the east’ was as cold - felt like it due to the wind chill effect, but not such low temps for so long.
It passed th Beast from the East test of -18 oC for 40 odd hours with honours , it could be that having the insulated condensate discharge in to the drain below the plastic cover kept it safe .Likely not been a cold snap, like this, in the last seventeen years! I don’t think ‘the beast from the east’ was as cold - felt like it due to the wind chill effect, but not such low temps for so long.
Water has has also blown the upstairs electrics. I did my bit of turning off the water and left for plumber & electrician, or whoever, to sort out the cause. Insurance claim will have to be made due to damage.After driving a 70mile round trip, with a wheel, to rescue the other half (no spare in her Fiesta), I insisted she did the same for similar reason. After making her buy a spare wheel, jack and brace.In these days of so called equality what else do you expectYears ago my mother had a flat tyre and asked me to change the wheel for her but I made her do it herself with me watching so if she ever had another one ,out in the fens with no help available , she would know how to do it
Screw Fix same road as Mac Donald's in Cross Hands sell insulating foam filler at about £2.60 a can . When I sorted the rubbish job done by " professionalOur mains water frozen again this morning. Not surprising at -9.5C mid afternoon!
Use the hot air paint stripper again. Tonight I am filling the hole where the pipes and valves are with pop bottles full of hot water!
plumbers" I use a full can to seal both sides of a cavity wall,, Pushed some cling film covered cardboard over the outside to try and get a filling fit , left it for three days to fully expand and cure then sliced of the excess inside & outside .
