mechanical music
- england uk
is it possible to weld an aluminium cylinder head with a sip migmate 130, or is it way to small
point taken, your pics show what looks like a professional repair, what i paid a blacksmith to do came back with damage that wasnt there as the new post have been ground so rough that they now have dips each side and the posts dont even look wide enough compared to original, so ime not pleased at all, thanks for your adviseHere are some horrors I've put right after someone else had a go......
View attachment 371878View attachment 371879
i dont have the correct wire/gas yet, but ive just been told the amps are way too low so not worth trying unless i win the lotto and buy a tig etc, thanksIf you have a scrap head why not give it a try?
You could then post some photos of your attempts on here and the experienced can offer advise on how to improve.
To do it right the flange needs milling so the gasket faces are flat. It sounds like yours was done with an angle grinder which won't give the tolerances required.point taken, your pics show what looks like a professional repair, what i paid a blacksmith to do came back with damage that wasnt there as the new post have been ground so rough that they now have dips each side and the posts dont even look wide enough compared to original, so ime not pleased at all, thanks for your advise
To be honest all that needs doing again completely or it will just fail.my initial quote was £40 for all 8 post/ stud holes to be filled slightly above the top so i could grind them down myself to save paying for that part, then it turned out i only needed 2 doing, and he still wanted £40 and ground them like this, ime drilling and tapping them myself....hopefully
i totally thought the same thing, wasnt sure if it was just me expecting too much, its a head i recently bought off ebay for a bike project ime rebuilding/restoring, i paid too much for the bike as ive had to weld a piece in the frame as it was badly rotted, only to pay for more damage, ile be blasting the head and repainting everything, but might get the head rewelded, ime making a template for drilling the exhaust stud holes square before tapping themTo be honest all that needs doing again completely or it will just fail.
For a start the head is absolutely filthy and the weld has porosity down the side of the post so it's compromised.
The gasket seat is also butchered so it needs building up and re boring.
Once you drill and tap the holes I'd be surprised if there isn't voids in the thread.
its off a yamaha fzs 600 mk1, ime not too bad in general, but only got a small piller drill that takes a handheld drill, ive nearly finished making the drill templateWhat are the heads from?
It’s a machine shop job but if your a skilled chap with a decent pillar drill you could do it at home
any suggestions on the best way to degrease it before i have it rewelded, ive got a home made vapour blast cabinet with fine glass beads but dont want to contaminate it until ive cleaned the headTo do it right the flange needs milling so the gasket faces are flat. It sounds like yours was done with an angle grinder which won't give the tolerances required.
This one had similar problems. Once the area is built up I then mill the flanges back to spec.View attachment 371882
Start with good old petrol then some water soluble degreaser. Just before welding clean the immediate area with acetone and a wire brushany suggestions on the best way to degrease it before i have it rewelded, ive got a home made vapour blast cabinet with fine glass beads but dont want to contaminate it until ive cleaned the head
