Probably but it was not thought about when it was purchased.No one has asked the obvious question: what is the SDS Max tool you wish to use? Does it have no equivalent in SDS plus?
Not really. A Max is only bigger diameter SDS would provide the same umph. Its only to remove tiles not concrete.I'm not sure it will work that well as the sds plus's drill might not be able to provide enough energy to drive the drill bit properly.
A bit like hitting a crow bar with a toffee hammer.
just use the proper chisels designed for your drillI need to use an SDsmax 18mm tool in an SDS plus drill and I can't find an adapter.
I can find ones going the opposite way but not to use sds drill with an sdsmax chisel
as already been said an adaptor will weaken its impaction from the drillI'm not sure it will work that well as the sds plus's drill might not be able to provide enough energy to drive the drill bit properly.
These.just use the proper chisels designed for your drill
you dont need to use an sds max drill bit, what i believe its you thats wants to use one of that size when the other chisel bits are just fine to use
as it goes for chisels i prefer the larger bit to use when chiseling tiles off the wall
SDS Plus Chisel Set
For a range of chipping and chiselling tasks, this set of SDS Plus shank chisels from Toolpak is just the job. The pro-quality chisels can be used for light-duty breaking and render removal as well as a range of standard chiselling tasks.Made from high-grade alloy steel, the robust Toolpak...www.toolstation.com
Is it? I just assumed it was the usual sales gimmick by making it thicker.A max is a very differient beast to a plus.
A sds and sds plus are the same but differient.
More a case they have already purchased this.
tell your son to tell the purchasing department that they need to buy a sds max drill thenIt not my drill mate. It's what you get when you put supplier selection in the control of the purchasing Department
Well not strictly accurate. More a case they have already purchased this.
And it's a case of my son needing to get the job done the easiest way possible. Now the purchasing Department cocked up
This is the real world mate. Office staff always know best...loltell your son to tell the purchasing department that they need to buy a sds max drill then
use the tool and the tools to there designed specification if your adjusting it then its a health and safety matter if it goes wrong
theres always a chance that it will go wrong
they bought the wrong thing let them sort it
well your son has the right to refuse to use that tool suppliedThis is the real world mate. Office staff always know best...lol
why should he ?Can you not hire a max drill for a day or so?
Might be quicker / cheaper.
