doubleboost
- Newcastle upon Tyne England
Good tip!!If i go to buy paint or solvent .
I make sure it has pictures of dead fish on the label
I always look at the VOC label as well and it goes straight back on the shelf if it says Low VOC. Only the High VOC stuff for meIf i go to buy paint or solvent .
I use zepp, it's pretty goodI just used a tin of environmental friendly engine degreaser that does not degrease anything.
Neighbour was telling me, they dip bulbs (the flowering kind) to stop them from regrowing the following year. Just so you have to buy more.
(Stop the bus I want to get OFF)
That fish isnt deadIf i go to buy paint or solvent .
Try a spray / trigger pack of the amazing " Elbow grease " from the likes of the B&M .I just used a tin of environmental friendly engine degreaser that does not degrease anything.
That's because you didn't know how to give her a good servicing .I had a girfriend with Dysons Disease
whined a lot and wouldnt suck ... does that count![]()
Tom next time you see your Dulux man can you please ask him what has replaced the old oil based brilliant white that does not chip or yellow like the newish ( sold in the last 15 yrs or so ) Dulux low odour acrylic white does ?Messing aside , I was varnishing a floor in a rental property ,,, normally I use 2k and think nothing of it , but next door has a new born etc etc ,, so the next choice for me was an oil based tough varnish , I spoke to a friend of mine who works for Dulux , long story short the recipe for oil based varnish has had to be changed so much to meet regulations , the water based acrylic varnish [ that I only ever thought of as diluted squash ] is now tougher than the oil based floor varnish ,,, and it goes on with a sponge ,,, crazy world .
Can you give for use inside your house high VOC paint names & where to buy them please , I'm sick of this chipping, cracking, yellowing, white acrylic rubbish that's now common place,I always look at the VOC label as well and it goes straight back on the shelf if it says Low VOC. Only the High VOC stuff for me![]()
Im using a great white at the moment ,,, Ill check the can tomorrow , and a great emulsion too ,,,,again I will check tomorrow .Tom next time you see your Dulux man can you please ask him what has replaced the old oil based brilliant white that does not chip or yellow like the newish ( sold in the last 15 yrs or so ) Dulux low odour acrylic white does ?
My experience says the opposite, these close up's were taken a few seconds ago. Where the paint gets UV it is white, where it does not get any or much it yellows,That's strange, normally it's the other way around, the modern waterbased acrylics yellow far less than the old oils and alkyds - unless you have contaminants from old oil paints underneath them.
pity you wernt near ruffoth the guy sells it for 30 quid a drum . proper stuffI go out of my way to NOT buy these 'environmentally friendly' products as I know they're all 100% carp.
Paint stripper? I always buy some 'professional use only' stuff with DCM in it off ebay etc. Works just like Nitromors used to before it went eco.
Creosote? Need some of that for my various sheds so I'm going to buy a 25 litre drum which is about the smallest you can get now, again professional use only. No way will I entertain the substitute Creocote nonsense that everyone is flogging now.
The latest thing I've tried, on the recommendation of a painter & decorator friend of mine, is Johnstones Trade Professional Undercoat and Satin top coat, both oil based. I painted a few skirting boards with it and it's good at taking knocks without marking / chipping. It also went on nicely but one thing that's weird with it is it gets a slight yellowy / greeny tint to it where it DOESN'T get exposed to UV light (e.g. behind a cupboard). Expose it and it goes white again in a couple of days, bit strange!Can you give for use inside your house high VOC paint names & where to buy them please , I'm sick of this chipping, cracking, yellowing, white acrylic rubbish that's now common place,
It used to be that the old Woolworth & Dulux paints lasted at least seven-years before you needed to repaint, now you're lucky to get away with two years before having to think about doing it.
