Hello everyone, this is my first post so I hope you will be kind
I am embarking on a new project to build an off road buggy, which also means learning how to weld. I have already gained a lot of knowledge by reading these forums, but I'm stuggling a little with the best tool for cutting box section.
The majority of the frame will be made from 1 1/4" by 1 1/4" 14swg box section, and I will need to make a lot of angled cuts. As far as I can tell I have 4 options; 1. By hand 2. Grinder 3. Chop saw 4. Band saw. Option 1 is out of the question, 2 and 3 are noisy and I don't want to annoy the neighbours which leaves 4. I have a pretty small budget (less than £100) so will be looking at second hand tools.
Is a smallish bench mounted bandsaw suitable for cutting box section and is any bandsaw capable of cutting metal with the right blade? If you have any recommendations for a particular brand/model I should be looking for that would be a great help. Thanks in advance for any/all advice.
I am embarking on a new project to build an off road buggy, which also means learning how to weld. I have already gained a lot of knowledge by reading these forums, but I'm stuggling a little with the best tool for cutting box section. The majority of the frame will be made from 1 1/4" by 1 1/4" 14swg box section, and I will need to make a lot of angled cuts. As far as I can tell I have 4 options; 1. By hand 2. Grinder 3. Chop saw 4. Band saw. Option 1 is out of the question, 2 and 3 are noisy and I don't want to annoy the neighbours which leaves 4. I have a pretty small budget (less than £100) so will be looking at second hand tools.
) but pretty noisy
