Hood
I am obsessed.
- Carnoustie, Scotland
That was the last cruise control speed I had set.What's the 74 mph displayed for?
To be more accurate, I think that the terminology used over here might be something like "frost-proof anti-siphon sillcock" or "freeze-proof anti-siphon hose bib" (or "...tap" "...spigot" "...faucet," etc.). The idea is that even though you connect the hose outside the house, the actual valve for that tap extends inside the home to a heated area, such as a heated basement. We've had them on our houses for many years, and we've never had one freeze yet, even in below-zero Fahrenheit (below -18C) conditions. They are installed with a slight slope for drainage and an anti-siphon valve to prevent backflow. You should always disconnect the garden hose before freezing weather sets in, so that it can drain. Otherwise, water trapped in the pipe between the valve and the hose bib could freeze and burst the pipe.Freeze proof taps.
Care to elaborate on that, please.
I'm sure it's already been at the limit anywayThat was the last cruise control speed I had set.
Nah, too old for that nowadays.I'm sure it's already been at the limit anyway![]()
Grabbed some scrap aluminium from the skip and took it home. Bent a rough ring by hand and welded it all up, much faster than waiting for procurement to order a binbag holder for the cabin
this morning I was cleaning a paint brush and as usual having a problem getting all the white spirit out and the came up with a new to me idea. If it's common practice forgive me but regardless it does work well. Just be careful which way you point it and don't do it indoors.Today I made nothing but a complete f up of stuff. When to paint a few parts. Paint was a little thick. Went to thin it down and spilt a big load of thinners ruined a new pot of paint. Ripped the zip off my temporary shelter so everything got wet as it has to slash it down. All in all a up yours day really. Still not happy with my paint finish
We have taps in the house, you turn off, then a bleed pointTo be more accurate, I think that the terminology used over here might be something like "frost-proof anti-siphon sillcock" or "freeze-proof anti-siphon hose bib" (or "...tap" "...spigot" "...faucet," etc.). The idea is that even though you connect the hose outside the house, the actual valve for that tap extends inside the home to a heated area, such as a heated basement. We've had them on our houses for many years, and we've never had one freeze yet, even in below-zero Fahrenheit (below -18C) conditions. They are installed with a slight slope for drainage and an anti-siphon valve to prevent backflow. You should always disconnect the garden hose before freezing weather sets in, so that it can drain. Otherwise, water trapped in the pipe between the valve and the hose bib could freeze and burst the pipe.
Here are a couple of links:
https://www.denommeeplumbing.com/outdoor-faucets-make-winterizing-a-snap/
https://www.quora.com/How-do-Frost-free-faucets-work
Of course, if the anti-frost valve extends into a cold or unheated area, that area may not be warm enough to prevent the valve from freezing, so all bets are off.
Go on, I've missed this, or not been paying attention, or both.here is some work ive done to the grinnal recently, i made two rails with a sliding frame powered by a12v winch to elevate the drivers seat , then sussed out some hand controls using an old audi clutch pedal as a push lever with
a thumb operated throttle and hand clutch
pushing lever works a 12 mm square box section with rose joints boted to the brake pedal all works well and passed mot no problem
ive been through the whole car and seviced thoroughly its all legal now
but i was so dissapointed that i couldnt
get my gammy leg high enough to transfer off my chair without up ending it hence the recent buy of a ceiling lift
hopefully be out for a trash soon
next project will be a davit type thing in aluminium so i can get out when i go for a View attachment 348890View attachment 348891View attachment 348891View attachment 348892View attachment 348892View attachment 348893View attachment 348894View attachment 348895View attachment 348897run View attachment 348896
bmw flying brick powered 3 wheelerGo on, I've missed this, or not been paying attention, or both.
What is it, vrrmmm, vrrmmm, poop, poop ?
A tricycle, cool !bmw flying brick powered 3 wheeler
with loads of goodies only 5k miles since it was built , first job ground all the flaky chrome off the roll bars and added extra fittings for future mods tView attachment 348916View attachment 348917View attachment 348917View attachment 348917View attachment 348919View attachment 348920
That's basically what we did when we had houses with standard outdoor taps. With frost-proof hose taps, we just shut off the tap and disconnect the hose...no bleeding or separate shutoff required. The downside is that the frost-proof taps are more expensive and are a bit fussier to install, as they have to have some slope to them, which sometimes requires boring a new hole in a sill or foundation wall or altering the old pipe hole a bit if you're upgrading.We have taps in the house, you turn off, then a bleed point
at the lowest point, and leave exterior tap open.
It will be damage to your legs & nether regions if you don't get the edges nicely rounded ED.... guess how I knowOne of two picnic benches
Will find out what the damage is when I get the invoice from the builders merchants for the timber...
