Here's a propane cylinder which I'm trying to turn into a woodburning stove. This first firing was used to burn off paint from the cylinder. I hope to add an electric fan for the air intake. I will also try placing some storage heater bricks inside to see if they enable the unit to give out heat for longer. I used door hinges which cost 59p for the pair from Screwfix - the only major cost of the project, so far. I welded a bar inside the door in an attempt to prevent the door from warping under the high heat.
looks really well. Is it neccessary to weld a bar on the door to stop it from warping and where and what angle do you install the baffle plate
