julianf
- devon, uk
This thing -
I guess its about 30mm ish but obviously i can get the exact specs.
Metal pin and top bit need doing. Probably need to do a few of them. Maybe 500-off? Certainly an initial 250-off.
Pin is for electrical shorting, so, probably brass. Head has that irritating mushroom on the top, which prohibits simple moulding, so far as i can tell.
That resin printing would work. Filament printing would not give the finish required.
The brass bit, i assume, will be a job for my collet lathe, once i put it back together again. I mean wire cutters and a sander would so it, but i think the collet lathe will be quicker. Just not too sure about the head?
Thank you.
Thank you.
