There isn’t one.
I sell a decent number of firepits and smokers. I spent a lot of time finding out the best paint.
Mipatherm is the one to get but it’s only available in a tin. Ready to spray but you’ll need a spray gun.
All the aerosols I tested, and it was most of the ones I could buy easily, were ****.
You’ll want UHT for an exhaust I’d think.
I don’t think so but no pic of can that I can see so can’t be sure. None of the aerosols were very good to be honest. It’s the coverage. You need to get it on evenly then bake it as per the instructions with VHT /UHT paint. It’s quite fussy stuff. If you don’t do it right it’ll work but won’t last.I take it youv tried this?
High Temperature / Heat Resistant Paint - Matt Black - Thomas Graham
www.arc-rite.co.uk
Weirdly enough I was at the blasters earlier and we got talking about itI use this guy
It’s all in the prep. If you can, get the exhaust off the bike and get it blasted and roughened up a bit.
I did bake it but still looked poor to start with and if you touched it with your finger it looked awfulI don’t think so but no pic of can that I can see so can’t be sure. None of the aerosols were very good to be honest. It’s the coverage. You need to get it on evenly then bake it as per the instructions with VHT /UHT paint. It’s quite fussy stuff. If you don’t do it right it’ll work but won’t last.
What I found anyway. I spent ages and a lot of money testing it as I didn’t want any back and touch wood I’ve had none
That stuff you need to maintain at 400 for an hour then slowly increase to max operating temp. Not sure how you’d do that on an exhaust. A cardboard box fire is about the right temp if that helps…..
I did the same to mine as that’s what Iv always doneI warmed it with the heat gun for a bit, then fitted it up on the bike, ran the engine for a few minutes, then switched off, repeat a couple of times then off to the hills!
That would be a real PITA to doThat stuff you need to maintain at 400 for an hour then slowly increase to max operating temp. Not sure how you’d do that on an exhaust. A cardboard box fire is about the right temp if that helps…..
That’s gorgeousI warmed it with the heat gun for a bit, then fitted it up on the bike, ran the engine for a few minutes, then switched off, repeat a couple of times then off to the hills!
Anyone tried hun blueing, would it work and be durable on a bike? @northwest
