I think your own words do that best.Does it? Why? If you strongly believe that's the case, can you explain why the following is incorrect?
"It uses more fuel" is what people are told but show me a real world test. Or, at least, attempt to explain with some logic/physics
"a seat of the pants guess at best!"
Most modern high (especially diesel) efficiency cars have very little over run engine braking.
Your going down hill so any engine braking effect is more than covered by the effect of gravity.
The little braking effect there is is helping you maintain control (speed & handling).
You started at the top if the hill at max legal speed so there is no speed increase gain to be had.
You would keep that max speed with or without coasting.
With coasting you will also need to use the brakes.
