Yes, They sit in shaft tubes but the water doesn't naturally change much.Are thes out of the boat ?
So clean out the pits as best I can and the pickling paste?You need to mechanically remove what is causing the pitting which is probably ferrous material. This can be done with a wire brush grinder.
Then passivate With something like this:
Antox 71E Plus Pickling paste
<font color="#ff0000"><strong><u>Pickling paste is only used for the removal of weld burn on stainless steel.</u></strong> <br><br></font>Available in 2kg tubs with acid resistant brush. <br><br><strong><em><u>Discounts available on 6 x 2kg case purchase.(see discount page)...www.elmerwallace.co.uk
I would but they are 12 feet longIf they’ve been in the water for 28 years I’d be surprised if they will get much worse.
what about digging out on a lathe, pre-heating and a spiral weld repair?
that or have some new ones made…
if you can avoid welding shafts do so.I would but they are 12 feet long
