Lewis_RX8
- Scotland
First of all thanks to @Kram for sending the knurl wheels through and giving me the idea for this project it was really good for learning a few things on the lathe and mill and gave me a project to fill in time between other bigger ones hence why it has taken so long.
So this was the rough idea , I wrote down the dimensions later , I was aiming to copy this type of clamp style tool rather than just a push tool as at the time I only had the mini lathe at home and did not have the ridigity or bearings to push that much force so went for a clamp so the force is on the workpiece sqeezing it.
Aplogies for the intermittent photos it got to a point of getting a little carried away working and forgetting to take the phone out and record but you get the idea
Got my bars cut out of a long bit of 10mm flat bar I have from a scrapyard and milled these all down to square
Then it was time to make room for the knurl wheel to sit , As i have quite a small mill I try to remove as much material with drills and cutting before using the milling cutters to do the finishing cuts rather than plunging into a big deep cut.
I also had to do some work with the files and hacksaw aswell just to tidy bits up etc such as removing the small bit in the last photo.
So after making the two arms I made the main strut with was alot nicer to machine on the outside taking small cuts rather than cutting the slots for knurl wheels as it was harder to do smaller cuts. it gave me the rough idea assembled and was quite pleased with it
Ran out of photo space so i will continue in next post
