I've always struggled with CAD software. I always find it horribly unintuitive. At the last count I had three different CAD programs sampled on my desktop, there will be others that have been downloaded and uninstalled too. Basically, I have a massive blind spot for CAD.
I thought I would mention the two programs that I can actually manage with. Drawing software for people who can't do it sort of thing. I'm sure there's plenty of people on here like me. I also know that there are many people on here that are really good with this stuff and will have their own preferences.
I have got on well with Emachineshop but it is rather basic and the current version won't let you export DXF files unless you pay for it. It seems to be the one that UK people with plasma tables on Youtube use to knock up simple designs. The older versions are the ones to have.
I have found another program that is broadly similar for ease of use as Emachineshop. Fusion 360, in the sketch mode at least for basic elements. It will create dxf files too. Even the cut down free version I'm led to believe. It's a very powerful tool but the sketching bit I've found is nice and simple to use.
I'm not really here to discuss the pros and cons of the software too much. Just to point out I've found this one OK to use as someone who bangs his head against the wall usually. It even has a graph paper background to make me feel more comfortable.
I've managed to draw stuff up like this relatively easily
3d Model too, using the extrude function to give it depth. Never thought I'd see the day. It's part of a sheet metal roller knocked up from memory of the dimensions I used on the real thing. I've been practicing by drawing what I know.
Below are a couple of extremely simple models drawn of trailing arms that I made a few years ago. At the time I ended up drawing them out full size on graph paper as I needed to know the length of tube to cut for 305mm centres and I couldn't picture it in my head. For the 20mm tube that I finally used I was only about 1.3mm out. The inaccuracy was probably down to having two paper sheets joined with sellotape plus the pencil lines. Close enough.
I've found this bloke is a very good teacher too. Personal preference of teaching styles will play a part here of course.
My takeaway point and reason for the post is maybe try Fusion 360 if you have tried and failed with other drawing software. I wish I'd found it years ago. Here's a screen shot.
