I've snapped the overhead cable to my house. I've done a temporary repair and got the phone working but does anyone know of waterproof joint with strain relief ?
I didn't know that. Does the same apply to the gas supply if someone hypothetically cut it through with a digger.Openreach use them all the time, which is who should be doing the repair if its on their side of the phone socket, its illegal for you or anyone else that isn't Openreach or their contractors to do so.
they dont have strain relief thoughYou want jelly crimps for the corrosion protection and then just encapsulate it in errr somthing.
Posted wrong link edit
Would this hypothetically cut gas line on the supply side of the meter, cut with an excavator bucket that was fully elevated as the driver reversed the machine, hypothetically have taken out the overhead phone line?I didn't know that. Does the same apply to the gas supply if someone hypothetically cut it through with a digger.
cleveland cable company.they suppl;y openreach and everyone elseOpenreach won't repair, they'll simply replace sections between wherever they can add a joint that won't be under strain i.e. on a pole, or the side of a building.
If it's too obvious how it got damaged, and you're likely to get a bill for Openreach repairing it, I'd be inclined to find a source of suitable cable to repair it.
sorry but we do overhead mid span joints all the time.Openreach won't repair, they'll simply replace sections between wherever they can add a joint that won't be under strain i.e. on a pole, or the side of a building.
yes but not if the overhead cable is damaged .only at the end after the restraining wire to make the down conection![]()
Dex Seal 2/4 External Telephone Joint Connection Box for Overhead Tele
Dex Seal 2/4 External Telephone Joint Connection Box for Overhead Telephone Cables - Dexseal 2/4 The DexSeal 2/4 is used for the connection of telephone cable externally, this external joint box is perfect for the connection external telephone or data cables, it's waterproof and includes jelly...www.bcedirect.co.uk
Thanks![]()
I've never seen them done on the final drop wire though, which is what I'm assuming the OP has burst, and not a bigger cable serving multiple lines.sorry but we do overhead mid span joints all the time.
