Hi all,
I'm halfway through making an engine crane from 100x50x3mm steel box section. I have encountered a rather big problem (as i see it), when i welded two uprights onto a 100x50x3mm section about 1000mm long. Due to the heat of the weld, it has bent both sides up! Can anyone reccomend a way of bending them back level? i have asked about heating the section up, but apparently i would'nt be able to fully heat it to bend it!!!
Please help,
Floydie
Please help,
Floydie
(as you can see in the pic). I have added a picture of the 3 bars welded together. In the picture, the frame is horizontal because i'm drilling through the two long parts, but the bent bar (as you might see) is standing verticle on a stool, if you look close you can see a slight bend from both sides of where the other steel has been welded. What advice would you give? as i need the part to be flat for the whole thig to work properly.
