Essentially.So I suppose its a cheap mans alternative to a hob?
I will clean them up over the weekendCan you post some clear pictures of the writing on them.
Its a science I know now I know next to bugger all about, having spent 20 yrs thinking I knew a lot, having had to work closely with a gear company and the Design Unit at Newcastle unit where the gear standards are kept over the last couple of years.
Chap i worked next door to when i was an apprentice did a lot of 1 off gears, he was seriously brightGear companies produce gears from hobs - had to pay a few grand for specific hobs for jobs over the last few years.
For general trivia knowledge, you don't machine a gear, you generate a gear.
I've got the Colvin and Stanley book.The best home workshop level book on the subject is Ivan Law's Gears and Gear Cutting. After that, Colvin and Stanley Gear Cutting Practice.
See: https://archive.org/search.php?query=gear+cutting&and[]=mediatype:"texts"
I think that's what he originally used, but then somebody created the LinuxCNC setup, where IIRC you simply entered the hob details, and teeth number, and it done the rest.I thought that John's setup has a bespoke adding circuit of some description? I think you can get stand alone controllers now with hobbing function but I'm stuffed if I can find where I saw one.
He just used frequency counters if i recallI thought that John's setup has a bespoke adding circuit of some description? I think you can get stand alone controllers now with hobbing function but I'm stuffed if I can find where I saw one.
That version used a divide by chip on a custom built card and the whole thing was designed by Brain Thompson and written up in MEW Vol 108
I got in touch with a local Linux Guru who set me a computer up to run Linux CNC instead of the dedicated black box.
I took the opportunity to upgrade the machine at this point and bought a new 400 line encoder from China £12.00, a new Breakout board £5.00 and a new driver and stepper motor which I had spare.
This now means that I can take as many passes as i want as it always stay in electronic mesh.
