gerrymoore
CNC expert (well, getting there!)
- Wirral UK
Campervan failed MOT on brakes and the master cylinder is faulty as pedal, under pressure, goes slowly right down to the floor. It's not ABS so should (I thought) be an easy fix...not! Van is 2003 and I cannot budge the brake pipe nuts. I've tried WD40 and will leave overnight but last thing I want to do is damage the brake pipes!! As I'm putting a new cylinder on, would I be OK trying some heat from a blowlamp to loosen the brake pipes?? Anyone any bright ideas? Thanks Gerry
