They produce a wet heat and put a lot of moisture in the air
I think that’s true
About 30ft x 12ft.How big is the area you want to heat?
What kind do you mean, I am looking into all options, thanks
Was that a space heater Paul?I had an Andrews diesel heater, warmed up an 1100 sq ft workshop no problem, never had a problem with moisture or fumes, if you do get bad smells it probably needs servicing, gave mine away to another workshop when I closed the place
Yeah, sorry should have said thatWas that a space heater Paul?
How high is the roof?About 30ft x 12ft.
Propane one made my eyes sting and gave off so much moisture it rusted everything in the shed.
Ones with an external exhaustWhat kind do you mean, I am looking into all options, thanks
That’s about it really.I recently bought one to dry out the mancave prior to painting, If its big enough to actually heat the place the fumes will kill you and if its too small the noise will do your head in.
Bob
Yes I sorta remember his review on the chinese diesel heater, I have been thinking about having one.
nuff saidI recently bought one to dry out the mancave prior to painting, If its big enough to actually heat the place the fumes will kill you and if its too small the noise will do your head in.
Bob
noisy costs a lot to run and stinks
