Farside
Badly Welded Man
- Ireland
I prefer to think of it as an ad-hoc engineered solution.Versatilty the new word for bodging then?![]()
the bigger ah square base battery wouldn't suffer as muchView attachment 280077
This little saw is excellent. The tiny battery struggles with sag but with a cut from each side 38mm boards are no problem. It will be sanded smooth and be a garden table.
I used to work for a guy who called them ‘micro solutions’I prefer to think of it as an ad-hoc engineered solution.
in the sensor not the hoseThe bore is already only about 3mm at the torch.
Yes that wouldnt sag much if at all, but I have a nice 12v 5Ah rc lipo I will eventually use as soon as I make the adaptor, but as it works well enough going slow I havent found the need to do it yet.the bigger ah square base battery wouldn't suffer as much
As a newbie, what’s going on in the pic? Looks like some box in old guttering?Yes that wouldnt sag much if at all, but I have a nice 12v 5Ah rc lipo I will eventually use as soon as I make the adaptor, but as it works well enough going slow I havent found the need to do it yet.
Derusting some tubes. Spent much of the day waiting for the water to heat up on my little hob/pan. I might get a new kettle for kitchen and keep the old for citric. Quite pleased that neither tube leaks.
I’m sure I missed an earlier conversation, what was wrong with the trenches? Or are they now for something? I’ve always wondered why people build brick work below ground instead of casting the foundation in concrete upto ground level (preferably to DPC level) what am I missing?today i made some trenches disappear and a wall get taller
Would that be internal rust? Seems quite clean on the top end judging from the pics..Looks like some guttering filled with citric acid and some box dunked in it to get rid of the rust.
the trenches i filled in are the ones in the garden, dug 5 years or so ago to put drains inI’m sure I missed an earlier conversation, what was wrong with the trenches? Or are they now for something? I’ve always wondered why people build brick work below ground instead of casting the foundation in concrete upto ground level (preferably to DPC level) what am I missing?
They are good bits of kit.Cutting shelves trying to bring some order into the garden shed chaos.
Bought a Keter foldable workbench a while ago but this was first time using it. Was half price when I got it. Wouldn't have payed full price for it though. Feels ok maybe a little flimsy and difficult to lock when folding it but better than my old B&D Workmate that was falling apart.
If it only last half time the B&D it's worth it
View attachment 280283View attachment 280284
I'm a bit jealous of your upcoming inspection pit. I'd love to install an inspection pit in our garage floor. Unfortunately, there are only a few inches of soil under the garage's concrete floor slab before you would hit solid bedrock or "ledge" as they call it around here, and cutting a pit into solid granite or gneiss isn't high on my list of enthralling activities for retired old geezers like myself.the trenches i filled in are the ones in the garden, dug 5 years or so ago to put drains in
the 'brickwork below ground' is the walls to my inspection pit.
