I saw a guy do that on YouTube. I wasnt sure how safe it was!Cut the valve off an old inner tube, take the nozzle off the can, pit the valve in a tyre Inflator, put the rubber (cut) end of the valve over the aerosol and push it against the can to seal it and give it a few blasts until you feel the can firm up.
Whats the construction inside normally? If i pierce the can will the stuff inside pour out or is it in an inner chamber? For a couple of cans this will work fine. For a few I will need to try the airline trick.Pierce the can and use it in a spray bottle or a canister with a air line
I save the tops off the aerosols when empty, most of the time if they won’t spray it’s the top blocked, just swap them over & generally they work again.
That looks handy....whats it called and where would I get one?Or this.
Easy to find suitable containers from 0.3l / 2.5l+
And only about 3 quid
I think many of us have done silly things with aerosol cans. Squirty builders foam is one that you have to be careful off. Very entertaining to pop a hole in one with an air rifle!
