Revs1972
- Torquay, UK
I was asked for my advice on some cracks that have appeared in the support columns on a building . These support a double A frame roof.
As you can see from the photo it is quite a sizable crack. They are around 150 years old, and there is no obvious reason why it has cracked. There is a smaller crack in the column next to it.
How would you go about repairing something like that ? From what i have looked at online you can gouge it out a bit and weld it back up, or there is a cold repair where you drill lots of holes and use connectors across the crack, backed up by drilling and tapping holes directly " in the crack" and screwing studs in then flushing everything off. Interesting process but can you do it on a curved surface ?
I think he is best off getting a Structural engineer in to check it and see why its happened. No good just patching it up if the root cause is not sorted out.
There are 7 of these in total (that you can see internally)
