doubleboost
- Newcastle upon Tyne England
This has had some stick
Grinding rivet heads off inside a steam boiler
I will see what the shop has to say
I don't have it bought on a card though . The Banggood one is still going strong .As long as you’ve got the receipt it shouldn’t be a problem
feels like bearings have sizedIs it burnt out or have the bearings gone John ?
that's the armature burnt out
How much did it set you back?
Interesting to compare the lifetime and cost of something like that against a Metabo or a Fein which is probably the best die grinder I’ve used to date.
I think it was 19 quid It has cut at least 50 3/4 inch rivet heads off
Sanding balsa woodI don’t know how they work without a receipt, shouldn’t be beyond the wit of man (or woman) to look things up and sort out a refund. Worse case it may have to go to head office.
obviously don’t tell em it’s had heavy industrial use. Light amateur home tinkering guv
Sanding balsa wood
