all its doing really is holding the two parts in alignment , once its in place it wont ever be an issue so it will be grand , the price wasnt grand though still whats done is done , just dont get them to do your gates or anything you can see.They installed it already... I am not the expert, have seen welding in factory settings that looks stunning.
It is nothing visual, so that is not something i care much about my main concern would be does it hold or is it just a bit of metal places on the column rather than attach 2 parts together properly.
haha! thanks. yes i think..
What would be the best entry welding for myself? just to do the small things in the shed
Life is usually much easier in a factory setting, you can set the conditions to suit yourself and work as comfortably as possible, whereas out on site, it's often the other way round. Had that been me, I would have tried to replicate factory conditions by setting the workpiece up to maximise my stability and comfort while welding.have seen welding in factory settings that looks stunning.
True you would set up for the best possible outcome i guess. I meant piping that has been made in an actual factory
Here the first thing that they came with and we send it away cause it was not as on the calculations..
- A friend in construction called this the worst welding he had ever seen![]()
Looks like he was running past it while pulling the trigger haha
Its a bit like a ten dollar hooker ,,, not very pretty but it will get the job done
[but I wouldn't know!
]you can do a lot with a simple cheap stick welder and a bit of practice...
It's traditional round these parts to weld two bits of metal together, rather than just weld oneTrue you would set up for the best possible outcome i guess. I meant piping that has been made in an actual factory
