- SW Scotland
So my wife's Defender 110 TD5 2002 Station Wagon has been in for a MOT and has sadly failed on a problem with the steering. It also has a few advisories as well, here is the rap sheet:
I'm going to try and help her out as much as I can, I may even do some of the welding on it
. Genuinely haven't decided yet; however, my knowledge of Land Rover intricacies is limited and I'm hoping some kind members will take pity and help my understanding on that front
I must qualify that I don't have a great deal of extra information from the person who did the MOT but I'll do my best to fill in as much as I can. The motor itself it not available to photograph for the post but should be in the next few days. I'll update if/when it's needed.
Beginning with the dangerous defect, "Steering rack has relative movement to chassis/bodywork persistently moving when jacked up" doesn't really explain what this is likely to be for me. Is there something that jumps out as a common cause of this defect?
She's been advised that the front steering damper is incorrect and checking on YouTube it does appear that this is true. It has a Bilstein gas shock rather than the expected oil-filled damper. There's no noticable pushing on the steering but I've not got a ramp and the person who did the MOT does so there would be less friction and the problem shows up I suppose?
I'm lumping all the welding related tasks together on the major defect list and advisories. She's no fool and knows a new chassis is going to be needed in the future but hopes to keep that date as far away as possible
If it comes to that then are there any recommendations for a good chassis supplier? She's looking at Richmond (IIRC, she's on the phone right now so cannae check), they seem to decent? I'm leaving any diagnosis of that until I can get a look and feel of the job in the flesh.
I've not done swivel pins or a clutch slave cylinder before but they don't look too onerous. Famous last words I guess
Anything else we should be looking out for given the above?
Finally, for the MOT testers themselves - what on earth is a "Nearside Rear Headlamp"
Sorry about the wall of text, there's a lot to it and wanted to try and get everything down in the OP
Code:
Do not drive until repaired (dangerous defects):
Steering rack has relative movement to chassis/bodywork persistently moving when jacked up (2.1.2 (a) (ii))
Repair immediately (major defects):
Nearside Rear Headlamp aim too low offside front (4.1.2 (a))
Offside Front Axle swivel pins and bushes swivel pin and/or bush excessively worn (5.1.2 (b) (i))
Nearside Rear Wheel bearing has excessive play offside rear (5.1.3 (a) (i))
Nearside Rear Shock absorbers has an excessively worn bush (5.3.2 (c))
Offside Front Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 (c) (i))
Offside Rear Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting seatbelt mounting at crossmember (6.2.2 (d) (i))
Offside Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting crossmember at body mounting corroded (6.2.2 (d) (i))
Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting centre crossmember at tow ball corroded (6.2.2 (d) (i))
Offside Front Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting nearside front crossmember corroded (6.2.2 (d) (i))
Front Intermediate drop arm insecure (2.1.3 (a) (i))
Monitor and repair if necessary (advisories):
Nearside Rear Lower Shock absorbers has a slightly worn bush offside rear lower (5.3.2 (c))
Nearside Rear Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security seatbelt mounting at crossmember corroded (6.2.2 (d) (i))
Nearside Front offside front hub seals slight leak
clutch slave cylinder leaking
If it comes to that then are there any recommendations for a good chassis supplier? She's looking at Richmond (IIRC, she's on the phone right now so cannae check), they seem to decent? I'm leaving any diagnosis of that until I can get a look and feel of the job in the flesh.I've not done swivel pins or a clutch slave cylinder before but they don't look too onerous. Famous last words I guess
