seen a video drilling through a Rail, masonry, tiles vurtually anything...same drill
anyone tried them
https://equalizerdrills.com/
anyone tried them
What, drill different sized holes? That would be a superb drill bit!if they are that good , and they gave you a free sample ,
they would never sell any , you would have the one they gave you free and it would do all you ever needed.
anyone tried them
if they are that good .... wiggle it ,,, im sure its a technique youve used before ,,, lolWhat, drill different sized holes? That would be a superb drill bit!![]()
but say they will replace one if u bust itall my masonry bits get sharpened from an impact edge to conventional drill faces so they cut through metal and wood as well as masonary .u can readily buy them there called bosch multidrills they just don't make them past about 10mm I sharpen the long sds drills up to about 25mmAs Brad says they are re-shaped masonry bits...i have re-shaped my own masonry bits on my green wheel and drilled into steel as an experiment and they fly through...they don't like slow turning like on a bench drill as the carbide snags and just chips or snaps so mucho speed is the way they cut.
any pics? how long do they stay sharpall my masonry bits get sharpened from an impact edge to conventional drill faces so they cut through metal and wood as well as masonary .u can readily buy them there called bosch multidrills they just don't make them past about 10mm I sharpen the long sds drills up to about 25mm![]()
