Hi Guys, need advice with some gear from you electronic gurus as I have very limited experience with electronics.
I have a largish (about 10Kg) 240V AC to 39V AC transformer, the secondary 39V AC (unloaded) output leads consist of a 2x2mm wires each, so I am guessing that it would put out a fair few amps. (it came out of a very large UPS)
Now here is the reason for doing this, I want to power a 2500W max 50A 48V max input Induction heater or a similar one to this.
https://www.ebay.com.au/itm/2500W-12-48V-ZVS-Induction-Heating-Board-Flyback-Tesla-Coil-Module-Driver-Heater/392519509287?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
I have connected a MAX MO FSB 7510A 75A full bridge rectifier to those leads and get 35.9V DC unloaded and I assume that because of the F/B rectifier I am also guessing it will be at 100hz instead of the straight DC, am I correct so far?
When I connect a capacitor in between the output leads to get rid of the 100hz frequency it then becomes 54V DC. So if I then connect the 54V leads to the heater I think that there may be an issue due to the increase in voltage . The voltage will probably drop down a bit because of the load the heater will draw but it may still be too high for the induction heater and I may blow it up so I am wary of risking it.
My alternative idea:
Is to connect 4 x 18A/hr AGM batteries in series and then connect the 54V DC leads to the batteries (to charge them whilst the heater is running) and then connect the induction heater to 3 of those batteries.
Will the DC 100hz frequency make any difference or damage the batteries. If not, I could then use the 35.9 V DC@100hz straight out of the F/B rectifier (without the capacitor) with 3 x batteries in series, a bit low for 3xAGM batteries but it only needs to top up the batteries whilst the heater is draining them otherwise I will have to go to 4 x batteries. 4 batteries in series would give me more breathing room as the batteries could charge and tapping 3 of them should be about 39V DC which is well within the heaters specs.
Any advice on which way to go and will this work to power the heater or am I barking up the wrong tree? I am guessing that the frequency wont matter and I could just use 3 batteries.
Hope this makes sense!
Thanks.
Thanks.
or does it mean that that the 1000V limit would get reduced to keep within the 75A limit? Now that I have typed it out it actually makes more sense now and if that is the case, what is the max voltage at 54V or do I need a larger rectifier that is assuming if the tranny can even put out 20A.
