I’d there a difference between the ended 3 and 5Beware the super budget ones, they will print fairly well but they have a steep learning curve and the quality of prints will depend on a lot of tweaking and possibly upgrades.
The Creality Ender 3 is a pretty good bet for your budget. Not much assembly and should work right out the box so to speak. Has a big following so getting help is pretty easy.
So do you not think a Endor 5 is worth it for a beginner also is it a problem being the t frame over the cage is twisting and rigidity a problemEnder 5, Bigger build area(220x220x250 vs 220x220x300mm), twin Y axis motors (Ender 3 has single), Will be more rigid as it is a cage design ( vs T frame). Possibly upgraded electronics.
Ender 3 £210 ish
Ender 5 £350 cheapest I could find in 2 minutes.
I’ve used sketch up quite a bit before ( self taught ) but I’ve been reading up that it’s not the best one to useThere's probably more of a steep learning curve involved in the design software than the printer itself; if you've never done any traditional engineering drawing or CAD there's a lot to take in and figure out.
Do you think the bigger size would really be that invaluable for my self or would I be better reaching my limitations with a smaller machine and then if I feel the need then upgrading, also could I keep this in the garage with all my workshop equipment or would it be better kept in the home.You've got a head start then. I've been using AutoCAD for over 20 years, tried to get to grips with Solidworks which everyone says is the best CAD package out there, but I kept getting frustrated and always went back to ACAD. Also tried TurboCAD when it was on about version 4; any of them are cleverer than what I is![]()
Also would you suggest buying a designing package or just use a free oneYou've got a head start then. I've been using AutoCAD for over 20 years, tried to get to grips with Solidworks which everyone says is the best CAD package out there, but I kept getting frustrated and always went back to ACAD. Also tried TurboCAD when it was on about version 4; any of them are cleverer than what I is![]()
