MoreWellie
- Bedfordshire, UK
so far I've only refinished the swing arm and weights
thanks for the "golden balls" picture, had a good chuckle
what do you consider cheap
thanks for the "golden balls" picture, had a good chuckle![]()
If it makes you feel any better I had to deadlift it in the van by myself.Jammy git![]()
I got it.. loaded with a fork lift
Brace it well, the twisting is almost as bad as the weight. You will need to bolt it to the ground.I need to make a wee table for it now
But the most important thing is tooling. You can never have enough....
Have you been having a tidy-up Steve?![]()
Having a tidy up is good..as you find more space for goodiesI have been planning on that (for some time).
As the press hits the stop it will try and twist the table.I have some scaffie poles that I got for a drink so the plan is to use those for the table and I have a piece of 6mm steel left over for the top
Make sure it's very well braced.
Aye.as in x braces between the legs?
