Repaired a concrete mixer (just brushes)
An Hitachi H65AB2 (power cord,cord armour, switch, brushes and cleaned)
Check another concrete mixer (spares not available)
Check an old Hitachi impact (batteries and charger not worth to repair)
Check a Ryobi one plus charger (not worth to repair)
All this almost a week ago
Today took all them to the customer and got paid
Unfortunately I missed to make some photos but you know that it's part of what I do to live
I'm actually waiting for a customer that needs to repair another hammer
And another customer that needs to repair tow big electric hoist
About those hoist I will work only on the electrical parts just because I refuse to work on mechanical parts on this kind of devices
Answering to the question
"Why do you refuse to repair mechanical stuff on this kind of tools ?"
Because it's a kind of tool that lift heavy stuff ,this heavy stuff can fall down killing someone if I do something wrong.
There is a centrifugal brake in the gearbox if I mess up this particular part the results can be catastrophic
The secondWhats it like getting stuff in Sardegna, is there suppliers there or do you have to wait for stuff to be ordered ?
 Some will remember my posts about the air wrench I had ordered and found to be 'inadequate' for my intended use?  Well I raised a return request and eBay confirmed the Seller had 10 days [until 21st of Oct in this instance] to respond.
  Some will remember my posts about the air wrench I had ordered and found to be 'inadequate' for my intended use?  Well I raised a return request and eBay confirmed the Seller had 10 days [until 21st of Oct in this instance] to respond.   That'll cover the return postage which is part of the conditions, but still technically a profit.....
 turns out that when it arrived with the fabricator, there were 2 x sheets stuck together by the oil/waxy stuff they coat it with to forestall surface rusting in storage. He held off to see if he'd been charged for both, but no...only one on his invoice.  He said I might as well have both as he'd never use it but I made sure that my pal told him if there was a subsequent adjustment on his account with the suppliers I'd square him up so that he'd not be out of pocket - I'll def use him again for any sheet stuff I need as I can get round/flat/box etc in Inverness cut to size at decent rates.
 . Here's for more from the port authority
Very good. Good old fashioned common sense and ingenuity in action.
The spring has to be compressed to insert a 4mm 'spacer ring', won't fit back in otherwise. The old slave and bearing were just handy having just been taken out, along with a handy axle standWhat are you actually pressing though as looks like a clutch plate, release bearing and clutch arm??
That's proper hillbilly engineering.
Work of supreme importance done just now, new pizza tray now fits in Rayburn oven!
View attachment 196886 View attachment 196887
