Spark plug
- Durham, England
Get a tray of water big enough to fit the level in, put it in the freezer, wait for it to freeze, then without moving the tray you should have a flat surface.
So the easy way is to get a wooden batton and fix a tube to it and fill with water. The water will level itself. Then you have a reference. Get that level and you are done.
If you are up in Perth I have an engineers level, surface plate, some bars and gauge blocks we can sort it out.
LOL. So basically, you’re suggesting he should make another spirit level!
Personally I don’t think he deserves one...![]()
I think we're getting somewhere! If you set it on a "known" 30 degree slope then accidentally hit calibrate, it will call that angle zero. Are you with me?
Now when you turn it through 180 degrees and put it back on the same slope, it will read 60 degrees (or 300 depending on your model of level). DO NOT TURN IT UPSIDE DOWN!
So let's pretend you can stuff a wedge under that 30 degree thing, you want to wedge it by half the error being displayed which in this case we happen to know is half of 60 i.e. the 30 degrees you want to remove to give yourself a calibrated level surface. In general though, even if you don't know what the error angle is when it is reading zero, just turn it 180 and wedge up the surface until you remove half the reading, then hit calibrate, then turn it again, and again, and again...![]()
Just take it back to shop... Get a replacement.By jove, I think you've got it! Probably best not to use a scribe or permanent marker, but that definitely sounds like a plan![]()
That's exactly the point, it will be very very accurate over large distances. No good for very short distances though.I used to use a water level often in the boatshop for setting boats up for build or restoration, long bit of clear pipe, water & some food dye if you were feeling rich. Over thirty feet it was as accurate as i needed it.
Well, I've learned loads from this thread so I'm happyI can't believe this thread is still going or that people are still suggesting you introduce a secondary level to measure it against...
Well, I've learned loads from this thread so I'm happy![]()
